Engine management light
- Pendragon
13 Jan 2017 17:53 #176754
by Pendragon
Engine management light was created by Pendragon
Hi,
Hope someone can give me some ideas, after sitting around over Xmas I took my jimny for its MOT, on the way there the yellow engine management light or MIL came on out of the blue.
The car passed the MOT only needing a corroded brake pipe replaced, and the guy at the garage suggested the light may clear itself. So far it hasn't, the car seems to be running as normal and I have been reading various posts on here about fault codes, o2 sensors of which there are apparently 2.
I can't use the idea of bridging the connector behind the glovebox as I have an immobiliser fit, but as the engine is running ok does this mean it has gone into closed loop and is using the stored fuel air mix setting it had already?
I saw rhinoman suggest in another post about some sort of vacuum in the braking system.
I guess I need the OBD2 code from the system to be sure, but is it just the time of year for this sort of thing...lol
It's a great little car and the engine is strong, having just completed a top gear challenge from the Highlands to Normandy and back before Crimbo.
All advice greatfully received.....
Gav
Gav
14 Jan 2017 06:47 #176771
by kirkynut
Replied by kirkynut on topic Engine management light
Get the codes read or it's a guessing game.
- Pendragon
14 Jan 2017 13:11 #176784
by Pendragon
Replied by Pendragon on topic Engine management light
Cheers for the response, I read in Suisse thread that there are some cheap readers out there?
Mines an 04 plate with M13a engine, is it the OBD2 code reader I need?
14 Jan 2017 19:49 #176814
by kirkynut
I think that's the twin cam isn't it? I can never remember for sure! If it's a hard top it is. If so, yes you need an obd2 reader.
- Pendragon
20 Jan 2017 20:51 #177080
by Pendragon
- Pendragon
20 Jan 2017 20:55 #177081
by Pendragon
Picture didn't come out too well....
Code reads: P0130 O2 sensor circuit, bank 1 sensor 1
Time to create page: 0.203 seconds
