Reverse light switch 2005 jimny
  • mickt
09 Jan 2017 12:53 #176421 by mickt
Replied by mickt on topic Reverse light switch 2005 jimny
So you said the lights were not working. I take it you found the switch disconnected then? If so then that is probably the reason why! Reverse lights, like front fog lights, are not a mandatory MOT check item. But if they are fitted it is good to have them working!
  • Chriswilson86
09 Jan 2017 14:37 #176429 by Chriswilson86
Replied by Chriswilson86 on topic Reverse light switch 2005 jimny
Yeh the switch was disconnected they were working until a couple days ago and after checkin fuses etc ended up at the switch. The plugs been lined up correctly but its like theres something missing between the plug and the connector on top of the gearbox. Will try get some better pictures
  • mickt
09 Jan 2017 19:22 #176468 by mickt
I am a bit confused now. Is that a new switch then?
  • Chriswilson86
09 Jan 2017 19:53 #176469 by Chriswilson86
Sorry yeh its a new switch from suzuki. Going to take it back tomorrow cause i think its the wrong one. Not sure if theres differnt types or not
  • Damo666
12 Jan 2017 18:36 #176675 by Damo666
Replied by Damo666 on topic Reverse light switch 2005 jimny
I did a how to video a while back on changing the reverse switch. See if this helps.
Damo
Time to create page: 0.098 seconds
