Reverse light switch 2005 jimny
  • Chriswilson86
08 Jan 2017 20:17 - 08 Jan 2017 20:59 #176404 by Chriswilson86
Reverse light switch 2005 jimny was created by Chriswilson86
Hi guys. Just new to the forum and looking for some help. My reverse lights arnt working and located the problem back to the switch on the gearbox....problem is it wont just plug back in. The connector bit is still in the gearbox and ive got the cable with the plug. ive tried for over an hour and the both parts just wont plug back in together. Theres 1 spline at the top of the plastic connector and 1 spline either side but its like theres something missing from between the plug and the bit that goes into the gearbox. Any advice would be appreciated. Many thanks in advance, chris
Last edit: 08 Jan 2017 20:59 by Chriswilson86.
  • Chriswilson86
08 Jan 2017 21:00 #176408 by Chriswilson86
Replied by Chriswilson86 on topic Reverse light switch 2005 jimny
09 Jan 2017 07:47 #176411 by Busta
They should plug straight in :S
You may have to remove the sensor from the gearbox so you can get a good look at it and find out what the obstruction is.
  • Chriswilson86
09 Jan 2017 08:49 #176413 by Chriswilson86
Thsts whst i thought but its like trying to plug 2 male connectors together. Will try get it out as its abit tricky and tight to get into. Is it true thst its not a legal requirement to have them?
Thanks for the reply
09 Jan 2017 08:59 #176415 by Busta
It's clear from the pictures the connectors will go together if they are aligned correctly.
I don't believe it is an MOT requirement. I had mine wired to a switch on the dash when my gearbox sensor failed and I never had an issue with the MOT.
  • Chriswilson86
09 Jan 2017 09:22 #176416 by Chriswilson86
I alligned it up with the spline on top and the 2 either side but wouldnt budge at all. Will take it out later on and get a better look. Theres only about 4 inch of space so pretty tight with fat hands lol
