Repetitive banging under load
  • MattB12
28 Jan 2017 17:37 - 28 Jan 2017 17:44 #177430 by MattB12
Replied by MattB12 on topic Repetitive banging under load - FIXED
Just thought i'd update the thread.
Today I fitted a replacement transfer box from a 2005 VVT Jimny which had 43k on the clock - 20k less than mine. I picked this up from a local breakers for £120. Happy with that!
The chain was definitely slipping in the old box, it now drives fine under load and feels good again.
I've never tackled this job before on the Jimny but it was so easy and straight forward, I had it swapped over in no time. It is as simple as unbolting the props, unplug the 4wd connectors and unbolt the mounts, then it just dropped out with a bit of man handling.
I'm little worried that the chain started to slip so quickly after I fitted the 31's, i'm not sure if it's directly connected to this but we'll see how long this one lasts.
Transfer boxes, old on the left, replacement on the right.
Last edit: 28 Jan 2017 17:44 by MattB12.
29 Jan 2017 16:33 #177483 by Busta
Replied by Busta on topic Repetitive banging under load
Glad you got it sorted. Jimmy's are quite pleasant things to work on really! And £120 is a bargain.
  • Daniel30
29 Jan 2017 16:44 - 29 Jan 2017 16:45 #177485 by Daniel30
Replied by Daniel30 on topic Repetitive banging under load
Nice one - well done ;)
Last edit: 29 Jan 2017 16:45 by Daniel30.
Time to create page: 0.089 seconds
