Repetitive banging under load
- MattB12
17 Dec 2016 15:46 - 17 Dec 2016 15:49 #175741
by MattB12
Repetitive banging under load was created by MattB12
Hi all, 2007 VVT manual Jimny with electronic transfer. I'm hoping you might be able to confirm my thoughts on an issue
When under load in 1st and 2nd there is a very load repetitive banging until I ease up on the accelerator. Its coming from directly underneath me and i'm thinking its the transfer case chain jumping. Its so violent that it makes the chassis ring.
It doesn't do it in any other gear except 1st and 2nd where more torque can be applied. Another symptom - if i'm driving in 2nd, let off the accelerator and then put my foot down, the banging appears until I ease up.
Its the momentary increase in torque that's causing it. Pulling away from junctions and hill starts is where is most evident.
Has anyone experienced this before, are these the symptoms of a slipping transfer case chain?
Many thanks for your help.
EDIT: Just thought i'd add - initially I thought it might have been something to do with the rear prop so I took this off, put it in 4WD and drove using the front two. The banging under load is still there, which is why I'm thinking it's the transfer case.
Last edit: 17 Dec 2016 15:49 by MattB12.
- Thank you received: 706
17 Dec 2016 15:52 #175742
Replied by jackonlyjack on topic Repetitive banging under load
when did you last change/check the rear engine mount on the gearbox
Jack
Jack
- 1066Boy
17 Dec 2016 16:12 #175744
by 1066Boy
Replied by 1066Boy on topic Repetitive banging under load
I had similar noise last year. It was a broken transfer box mount. With the box hanging down a bit
the front prop was touching one of the chassis cross braces.
Cheap fix though!
- MattB12
17 Dec 2016 16:20 #175746
by MattB12
Replied by MattB12 on topic Repetitive banging under load
Thanks Jack, I haven't checked the mount actually, is it easy to get eyes on? Could a deteriorated engine mount cause such an abrupt noise and feel?
- MattB12
17 Dec 2016 16:24 - 17 Dec 2016 16:28 #175747
by MattB12
@1066Boy, this crossed my mind too. I checked the the transfer case mounts but they're fine and the front prop isn't coming in to contact with anything.
I got my hands around the transfer case and gave it a pull and a push, it felt secure.
Last edit: 17 Dec 2016 16:28 by MattB12.
17 Dec 2016 16:26 #175748
my 1st failure gave the repetitive knocking and got louder round right turns under load
£25 from suzuki
Jack
It's no so easy to see.But only takes 10mins to removeMattB12 wrote: Thanks Jack, I haven't checked the mount actually, is it easy to get eyes on? Could a deteriorated engine mount cause such an abrupt noise and feel?
£25 from suzuki
Jack
Time to create page: 0.092 seconds
