blocked pipes
- little boghopper
11 Dec 2016 21:26 #175557
by little boghopper
Replied by little boghopper on topic blocked pipes
sorry rich, i dont think i recieved your reply, (more like i didnt know where to find!!) serious big time new chap to forum things!
ill check my emails bud.
L
L
11 Dec 2016 22:51 #175564
by Busta
Replied by Busta on topic blocked pipes
It might be a good idea to check if the hubs are locked incase you need 4wd. To check: with the car in 2wd and all wheels on the ground get underneath and see if you can turn the front propshaft. Or with the car in 4wd jack up one front wheel and see if it turns freely. In either case if the wheel/prop doesn't turn round and round then both front hubs are locked.
- little boghopper
12 Dec 2016 10:56 #175573
by little boghopper
hey busta, the other day i jacked up the front end and it spins freely , i can see the prop turning and when engaged in 4x4, only moves a few degrees. so hubs must be locked. is this a problem on fuel would u say , or just leave it as it is.
cheers Liam. i guess repairing the vac hubs could be a pain in the axxe and expensive. will vitara hubs fit with spacers?
- wilku
12 Dec 2016 14:42 - 12 Dec 2016 14:44 #175579
by wilku
Replied by wilku on topic blocked pipes
If you have your hubs constantly locked and you do a lot of on-road driving the axles and the driveshaft are exposed to pointless wear (you know they turn, use up the bearings, inflict friction, shorten the oil and grease lifespan, etc.).
Just fit in manual hubs for Jimny (AVM 457 for example), OR:
get Vitara hubs and either: a spacer or replace the nut holding the wheel bearing (the one with 4-holes for a dedicated socket which costs approx 50GBP). The nut for Jimny has an inner lip, the Vitara / GV nut doesn't and that lip is what causes that Vitara / GV hubs need a spacer if you want them on a Jimny.
In any case I think it's cheaper to just get the hubs for Jimny (they are about 20GBP/25€ more expensive than Vitara/GV ones)...
And then, if you want to get back your 4WD indicator light follow a how-to about it on our wiki here.
Last edit: 12 Dec 2016 14:44 by wilku.
12 Dec 2016 18:13 #175589
by Busta
The extra wear caused by locked hubs is minimal. Certainly not enough to cause any issues. Some models of Suzuki's are fitted with fixed hubs from the factory.
- little boghopper
17 Dec 2016 13:39 #175736
by little boghopper
thanks wiki, i,ll try and find the how to's on here now!
Time to create page: 0.104 seconds
