blocked pipes
  • little boghopper
11 Dec 2016 11:02 #175522 by little boghopper
blocked pipes was created by little boghopper
hi, i recently noticed some pipes zip tied up behind the front hubs with bolts pushed in them, after a little research these must be the vac pipes
for the diffs yes? so now ill need some vitara FW hubs and some spaces from the jimny shop, plus long bolts? otherwise the front axles will be spinning constantly or is that not a problem? many thanks. L. attached 2 pics.
11 Dec 2016 11:29 #175524 by mlines
Replied by mlines on topic Re:blocked pipes
What hubs do you have fitted? Pictures?
Sent from my Nexus 6P using Tapatalk
  • little boghopper
11 Dec 2016 12:42 #175533 by little boghopper
Replied by little boghopper on topic Re:blocked pipes
hello Martin, many thanks for the super quick reply, i have attached a pic.
Liam.
11 Dec 2016 15:26 #175539 by mlines
Ok so someone has disconnected the vacumm pipes and blocked them off yet you still have vacuum hubs fitted.
At a guess it was to stop the 4WD light flashing when the car was sold, it makes it look like 4WD is working :(
Your choice it to fit manual hubs or to repair the vacuum ones. Most vacuum systems come back to life when cleaned up. I would suspect someone has been in the hub changing bearings etc and either damaged the hub nut or filled it all with grease.
11 Dec 2016 19:40 #175553 by Busta
Replied by Busta on topic blocked pipes
Setting the vacuum hubs to locked is simplicity itself. That may be what has been done here, in which case you will still have 4wd and it's nothing to worry about. The front axle will be turning all the time, but that won't do any harm.
  • little boghopper
11 Dec 2016 21:24 #175556 by little boghopper
Replied by little boghopper on topic blocked pipes
ta busta, i,ll not worry about it then and maybe addrsss after xmas, ,,, happen a snorkel in mean time !!
Time to create page: 0.110 seconds
