help/advice please.
22 Nov 2016 00:19 #174794 by Keithy
Replied by Keithy on topic help/advice please.
weecorey wrote: Thanks again, alternator is free as I checked that, I'll try the water pump tomorrow. Handy enough with the spanner myself, heads just up my arse this evening!
I get that regular!
No help on part numbers....I need a starter motor :dry:
22 Nov 2016 20:34 #174810 by weecorey
Replied by weecorey on topic help/advice please.
Changed both belts tonight, drained and refilled the radiator and expansion bottle. Took the car a drive and she's over heating, belt started squealing again water isn't circulating, bottom radiator hose is cold. Water pump was turning freely by hand but possibly not circulating water, think I'll try a water pump. On a positive note she didn't seem to be pressurising the radiator hose so hopefully head gasket is OK.
  • mickt
23 Nov 2016 19:05 #174840 by mickt
Replied by mickt on topic help/advice please.
If its not pressurising the tank then there is your overheating problem. As the engine overheated initially then chances are you could have damaged the head/gasket. Has the vvt engine got a damper in the crankshaft pulley like the M13 A engine? If so they are prone to delaminating and cause the belts to break.
23 Nov 2016 21:00 #174847 by weecorey
All sorted, when I filled the radiator and expansion tank last night after fitting the new belts I took the car a run, when the thermostat opened the coolant level dropped and there wasn't enough to be circulated with the water pump so she started to heat up, I topped the radiator up again and everything is 100%, temperature is normal and constant, water is circulating and level is good. I think this was just an old belt that was over due a change. Probably lucky its so cold and I caught the rise in temperature fast, no harm done.
23 Nov 2016 22:06 #174852 by Keithy
Nice result!
It's great when it all works out nice :beer:
24 Nov 2016 15:02 #174873 by weecorey
Yeah things worked out well on this occasion, happy days.
Time to create page: 0.116 seconds
