help/advice please.
9 years 11 months ago #174785
by weecorey
help/advice please. was created by weecorey
The alternator belt was squealing under load on my car, 2008 VVT JLX+, (I ordered a belt on Friday and I'm waiting on it arriving) Ive only bought this car 4 weeks ago and done 200 miles of the 67,000 on it. This evening it was squealing no matter and then it broke, about 1 mile later the battery light came on as to be expected, 2 miles after that I noticed the temperature guage at max and I pulled in and turned the car off, I could hear the expansion bottle boiling, felt sick! I let her cool down and drove the further 500 yrds home at a snails pace.
I cant get a good look this evening as I have limited lighting, the alternator belt is drive off the camshaft damper pulley which also drives the viscous fan correct? What drives the water pump? As I say I cant see much tonight but I did recover the alternator belt which was on the RHS of the engine and not the LHS where the alternator is located, it may have taken out another belt that I cant see at the minute?
Any advice much appreciated. Emmet
9 years 11 months ago #174787
by Keithy
Replied by Keithy on topic help/advice please.
The water pump is attached to the fan.....fan is bolted to it in fact......if you still had power steering you have no other belts broken....Heart sinks when an engine boils.....crossed fingers and see if you can find out the cause of failure?
The following user(s) said Thank You: weecorey
9 years 11 months ago #174788
by weecorey
Replied by weecorey on topic help/advice please.
So its likely that the water pump has failed as it is the camshaft pulley that drives the fan which is drove directly from the engine, the belt only drives the alternator which has no impact on the water pump, am I right in what I'm thinking???
9 years 11 months ago #174789
by Keithy
Possible causes are anything becoming seized which is driven by the belt, a foreign object impinging the belt(stone getting caught in it springs to mind)....or the stitching on the belt failing (mine is sewn as are a few I've seen)
Try turning the water pump and alternator by hand....you've done the hard bit..... removing the belt!
Maybe a nearby member could give a hand?
No you're in error....the crankshaft drives the water pump which has the vicious(some say viscous)fan attached.....if the belt breaks the engine charge light should immediately illuminate and the water will stop circulating.....leading to overheating of the engine....catastrophic failure and doom and gloom....or just replace the belt/whatever caused the failure refill water system and all's well that ends well....glass half full....chin up etc.weecorey wrote: So its likely that the water pump has failed as it is the camshaft pulley that drives the fan which is drove directly from the engine, the belt only drives the alternator which has no impact on the water pump, am I right in what I'm thinking???
9 years 11 months ago #174790
by weecorey
Thanks again, alternator is free as I checked that, I'll try the water pump tomorrow. Handy enough with the spanner myself, heads just up my arse this evening!
9 years 11 months ago #174791
by weecorey
I ordered a Gates belt 4PK833, anyone know the power steering/ aircon belt size/number?
Time to create page: 0.123 seconds
