Neutral rattle
10 years 3 months ago #171095 by Casey
Neutral rattle was created by Casey
Just noticed today that when I go into neutral and let the clutch out I'm getting a rattle like something is engaging. It stops if I put the clutch in. Any idea what it is?
10 years 3 months ago #171101 by Lambert
Replied by Lambert on topic Neutral rattle
Clutch release bearing probably. They can run like it for months or can die within days, my old scoobie lasted 14 months on an off before I could no longer get anything and had to change the clutch.
The following user(s) said Thank You: Casey
10 years 3 months ago #171110 by Casey
Replied by Casey on topic Neutral rattle
Thanks for the response. Much appreciated.
Just a couple more questions though. Is the clutch bearing separate from the clutch itself? Just wondering because it isn't that long since I had the clutch replaced. Is it possible to renew just the bearing or would it make sense to renew the clutch again at the same time?
10 years 3 months ago #171113 by j999pre
Replied by j999pre on topic Neutral rattle
The bearing is separate but comes as part of the clutch kit so should have been replaced when your clutch was done.
Ask the garage that fitted it as maybe there is warranty? Unless they just adjusted the cable and told you they had fitted a clutch. It's happened before.
Grey pick up Jimny
10 years 3 months ago #171115 by Casey
Thanks. I strongly suspect it's the latter.
