Splutter
10 years 3 months ago #170394
by Casey
Ieven though it's 15 years old 'm used to getting 70 out of my Jimmy on the motorway, but recently, when i get up to that speed the motor started spluttering and all the engine warning lights seemed to come on. Pulling on to the hard shoulder and turning the engine off for a few seconds cured the problem. However, last week on the motorway I had the same problem at 65 mph. Has anyone got any idea what's going wrong. Could it be the timing. If so should I look at getting a new belt/chain (which is it likely to be on a Y reg?).
10 years 3 months ago #170397
by j999pre
Grey pick up Jimny
Crank sensor problem
Grey pick up Jimny
The following user(s) said Thank You: Casey
10 years 3 months ago - 10 years 3 months ago #170415
by Busta
If yours is the twincam engine, the sensor is behind the alternator. When it starts stuttering, pull over and squirt some water on from a drinks bottle. If the problem goes away straight away the sensor is you problem.
The new part is £30-40, available on ebay and 20 minutes to fit. Slacken off the alternator adjuster bolt, lick the alternator belt aside and pivot the alternator over out of the way for easier access but if you have nimble hands you can do it without.
Last edit: 10 years 3 months ago by Busta.
Time to create page: 0.120 seconds
