Sheared ABS Sensor Bolt Removal
25 May 2016 08:57 #167435
Replied by mlines on topic Sheared ABS Sensor Bolt Removal
I had the same. Its actually quite straight forward
As it is sheared the ABS sensor is only held in by friction fit so can be prised out by tapping a screwdriver around its base.
This then leaves you with the remains of the bolt. I drilled it straight out and re-tapped the hole
- JimnyUser
30 May 2016 19:01 #167718
by JimnyUser
Replied by JimnyUser on topic Sheared ABS Sensor Bolt Removal
Time to create page: 0.091 seconds
