Sheared ABS Sensor Bolt Removal
- JimnyUser
24 May 2016 20:29 - 24 May 2016 20:33 #167402
by JimnyUser
Sheared ABS Sensor Bolt Removal was created by JimnyUser
So I set out to change the kingpin bearings on both sides of my Jimny today and first came up against a rounded torx bolt on the hub cover but managed to get round that only to be stumped by a sheared abs sensor bolt which either a previous owner or garage has done, Anyone got any ideas how best to go about removing the busted bolt??
Last edit: 24 May 2016 20:33 by JimnyUser.
24 May 2016 21:04 #167408
by kirkynut
Replied by kirkynut on topic Sheared ABS Sensor Bolt Removal
The sensor looks like it's held in only by its rubber seal. I would therefore pull it out, perhaps levering it with a fine flat bladed screw driver. Then get some penetrating fluid and heat on the bolt and then a pair of grips on what's left of the bolt.
- X8GGY
24 May 2016 21:07 - 24 May 2016 21:09 #167409
Replied by X8GGY on topic Sheared ABS Sensor Bolt Removal
Last edit: 24 May 2016 21:09 by X8GGY.
- JimnyUser
24 May 2016 21:18 #167411
by JimnyUser
Replied by JimnyUser on topic Sheared ABS Sensor Bolt Removal
I can see the bolt still in there so I'm guessing its holding it firm still. Yeah I was thinking of drilling the bolt out but might give one of these a go:-
www.ebay.co.uk/itm/New-8-Piece-Screw-Ext...1:g:MN4AAOSwBahU1LiG
- X8GGY
24 May 2016 21:26 #167413
- Spendersjim
24 May 2016 21:27 #167414
by Spendersjim
Replied by Spendersjim on topic Sheared ABS Sensor Bolt Removal
Take care not to snap one of those things off in your hole. :blush:
That would really spoil your day.
They don't drill too well. :evil:
Time to create page: 0.101 seconds
