Battery help!
12 Mar 2016 10:50 #163647 by Halford
Replied by Halford on topic Battery help!
Didn't want to start a new thread when I can hijack a closed one :whistle:
Just stuck a multimeter on my battery
No load 12.3 v
Cranking 8.6 v
Running 14.4 v
From looking at tinterweb the general gist is that if the cranking voltage drops below 9.5v then the battery is on it's way out.
Does any mech/elec expert care to help me out and confirm if it needs replacing ...?
she starts OK but doesn't sound like a strong crank and sometimes the alternator belt squeals for 20 secs shortly after starting with ac, rear demist and lights on - belt looks OK and at 14.4v I'm guessing the alternator is fine.
Suppose the battery is 9 year old OEM
Thanks for any guidance
  • mickt
12 Mar 2016 11:28 #163648 by mickt
Replied by mickt on topic Battery help!
Did you read my entry just prior to yours as it covers what you are asking?
12 Mar 2016 12:02 - 12 Mar 2016 12:03 #163651 by Halford
mickt wrote: Your battery needs load testing. Any good garage will do it for free as it is just a large handheld voltmeter with a load bank and a switch to load the battery and then they check the voltage. It should still maintain 12v when under load. Just get a new battery rated for the car as the alternator is matched to the battery as for recharging.
do you mean it should maintain 12v on crank
or
I have to go to a garage for them to check it
:huh:
Last edit: 12 Mar 2016 12:03 by Halford.
  • mickt
12 Mar 2016 13:08 #163655 by mickt
Both. A good battery will maintain 12v as the car starts as long as it is a "normal" start. I.E. it fires and runs "on the button" Obviously if it is a beast to start then any battery will have a drop in voltage if put under a high load for an unusual length of time. You could/should be able to kill both birds with one stone if you go to someone who supplies /fits batteries as they should be prepared to load test it in front of you to prove that they should sell you a replacement. Once proven it does need changing then shop around, you would not be obliged to buy from them and the check is normally free. Don't be fooled to get a high rated battery as the cars alternator might not be able to keep it at full charge. If the original is a 45AH battery then go for one very near to it as possible. Certainly no lower but say up to 50-55AH would be ok. Terminal orientation is important so you need one that is the same as yours as where the terminals are and the shape of them.
  • Daniel30
12 Mar 2016 13:15 #163656 by Daniel30
Replied by Daniel30 on topic Battery help!
Mine started to sound like it was having trouble turning over before it went all together after putting the new one on the difference is like chalk and cheese :)
13 Mar 2016 06:41 #163676 by kirkynut
Replied by kirkynut on topic Battery help!
The standard Jimny battery is only just up to the job when new, so an old one is going to struggle!
I remember when I fitted my 1000 cca Numax. I thought I could drive it just on the power of the starter motor it span over so quickly!
The following user(s) said Thank You: Halford
