Battery help!
  • Jim Jimny 95
28 Feb 2016 22:12 #163117 by Jim Jimny 95
Battery help! was created by Jim Jimny 95
Just got in my car tonight and tried to start it and it wouldn't start I believe it could be the battery as the alternator was replaced 6months ago, I have noticed a few times it struggles to turn over. Tonight I took the battery off the car and placed it on charge the battery has 13.8v which doesn't seem right. I believe the battery hasn't been replaced since the car was bought new 16years ago, the battery is a 12v Bosch silver S4 330A 45Ah could someone shed some light on what maybe causing it to struggle to start or tell me if the battery is indeed dead if so could someone recommend a better more powerful battery that will fit
28 Feb 2016 22:59 #163119 by Busta
Replied by Busta on topic Battery help!
The battery voltage shouldn't be reading 13.8v unless it is on charge. The best thing to do is get a proper battery tester that puts a load on the battery. Any good garage will have one. New batteries are pretty cheap so if it needs replacing it's not the end of the world.
  • Daniel30
28 Feb 2016 23:02 #163120 by Daniel30
Replied by Daniel30 on topic Battery help!
Just dont get one from halfrauds there very expensive :)
29 Feb 2016 08:17 #163123 by skywalker65
Replied by skywalker65 on topic Battery help!
A healthy battery will normally be around 12.7 volts measured across the battery terminals with nothing switched on.
What appears to be the problem is there's next to no ampage in the battery to crank the engine.
You can have situations where the battery appears healthy because the voltage looks ok but it doesn't have the strength ( ampage) to turn the engine.
Cold weather really kills batteries this time of year so it looks like you're ready for a new one. Always fit a decent battery and make sure you charge it before you fit. Don't always believe the patter that it's fully charged and ready to go. Unless the retailer can demonstrate they operate a proper regime for charging their stock of batteries, take it as read it'll want doing.
If in doubt ...... Flat out ??
  • gilburton
29 Feb 2016 19:53 #163146 by gilburton
Replied by gilburton on topic Battery help!
I don't consider a Halfords battery for £55 expensive with 3 yrs guarantee??
Yes you can get cheaper batteries but if bought on ebay or similar you can't just pop it back in the event of a problem.
Halfords is generally more expensive than other auto stores but it's there if you want something in a hurry.
I notice the OP has a Bosch Silver battery so I would expect that would be quite expensive and would last longer but I doubt it's that old as most batteries last 4/5 yrs although can last a bit longer with care and the original battery wouldn't be a Bosch..
  • Daniel30
29 Feb 2016 20:19 #163151 by Daniel30
Autosessive.com was £60.50 for the highest spec battery for the jimny halfords was £75.00 same battery
I got the next spec down from autosessive.com £48.00 4 year guarantee i thought that was good :)
Time to create page: 0.107 seconds
