Fuel Lines
  • Statey
10 years 9 months ago #161831 by Statey
Fuel Lines was created by Statey
As I've just removed the boot floor to fit a new one I'll need to drop.the fuel tank.
I've searched around the site about dropping the fuel tank to mka ethe Welding safe etc but what have people used for connecting the fuel pipes again?
Also is.it worth redoing the fuel lines while the boots out and what's the best thing to use.
Quick search Smoggie doing it with Copper but didn't know if any high pressure hose or silicone had.come on the market in recent years?
10 years 9 months ago #161845 by facade
Replied by facade on topic Fuel Lines
We luddites use copper, but modern cars have had all plastic lines for donkeys years now without trouble.
The tank is connected by plastic hoses sweated onto the steel ones, I just left 1" of the steel and used rubber to join to my new copper lines, so I could drop the tank.
At the tank the plastic line joins with those strange click together bayonet connectors that can be reused if you didn't break them.
I break pretty much every connector trying to get it apart though :blush:
  • OllieNZ
10 years 9 months ago #161855 by OllieNZ
Replied by OllieNZ on topic Re:Fuel Lines
I just unplugged the tank and dropped it out.
  • Statey
10 years 9 months ago #161856 by Statey
Replied by Statey on topic Re:RE: Re:Fuel Lines
OllieNZ wrote: I just unplugged the tank and dropped it out.
I'm hoping I can do the same but like facade ill probs snap everything so trying to cover all avenue's! Suppose first step is to drop the tank see if I snap anything haha
Sent from my Nexus 5 using Tapatalk
  • OllieNZ
10 years 9 months ago #161857 by OllieNZ
I already had the floor out, if you drop it it will swing to the right and keep the right end up there's a bit of flex in the pipes but if you pull it down level you'll stress the connections on top of the tank.
  • Statey
10 years 9 months ago #161858 by Statey
Replied by Statey on topic Re:Fuel Lines
Cheers Ollie, yeah my Floors out too so fingers crossed!
