SJ Vitara Jimny diff compatibility.
- Rockwatt
04 Feb 2016 12:22 #161850
by Rockwatt
Replied by Rockwatt on topic SJ Vitara Jimny diff compatibility.
Its not the ring that needs machining its the carrier!
The distance from ring face and bearing journal needs reduction and the bearing journal diameter also needs reduction to fit the smaller bearings. To fit a lockright and retain 22 spline then you could keep the diff standard and just fit it or use an jap sj front machined to fit that would give you a stringer 4 pun carrier
04 Feb 2016 17:17 - 04 Feb 2016 17:32 #161861
by Busta
Replied by Busta on topic SJ Vitara Jimny diff compatibility.
Ah thank you, I didn't know SJs had 22 spline front diffs! That makes it much easier.
Last edit: 04 Feb 2016 17:32 by Busta.
04 Feb 2016 17:39 #161863
by Busta
I was under the impression there was no Lockright that would work with the Jimny front diff but is the only issue that it's a 2 pin rather than 4? If a Powertrax 1510 will go straight in and work with the Jimny side gears then I'm sorted.
Time to create page: 0.083 seconds
