SJ Vitara Jimny diff compatibility.
27 Jan 2016 23:53 #161350 by Busta
I have been trying to work out the compatibility between axle parts from various suzuki 4x4s and haven't been able to find a definitive resource. Is there somewhere I could find this information?
I'd like to know which carriers fit in which third members, which crown wheel and pinions are interchangeble, which lockers can be made to fit where etc.
I know there is a lot of options for swapping between Jimny rear, vitara front and SJ413 front and rear diffs, but what about Jimny front? Are the crown and pinion the same as the rear? The side gears are 22 spline but is the rest of the diff the same as the rear/SJ/Vitara?
I've read Dave (S200KYS) thread on fitting a Vitara LSD in a Jimny front axle which was very helpful but there's still lots I can't work out!
  • X8GGY
28 Jan 2016 09:27 #161359 by X8GGY
Replied by X8GGY on topic SJ Vitara Jimny diff compatibility.
Rockwatt had to machine my front (Calmini LSD) crown wheel carrier down to get the crown wheel to line up properly with the pinnion, so it wasn't a straight swap...
See how the carrier has been machined down quite thin to get the crown wheel in the right position?
... but he made it fit of course! B)
I also had to widen the slot in the diff mounting flange in the axle slightly to to get the crown wheel into the axle...
It's in though! :cheer:
  • Rockwatt
29 Jan 2016 22:48 #161466 by Rockwatt
Replied by Rockwatt on topic SJ Vitara Jimny diff compatibility.
Jimny front diffs are high pinion and are only fitted to jimnys and coil sprung samurai's/sierras the carrier is is smaller and bearing journals are also smaller.
If your looking for a resource of all the info you could try drilling into my head lol ! might be scary what you find in there! Some say..........
  • OllieNZ
30 Jan 2016 07:47 #161473 by OllieNZ
Replied by OllieNZ on topic Re:RE: SJ Vitara Jimny diff compatibility.
Rockwatt wrote: Jimny front diffs are high pinion and are only fitted to jimnys and coil sprung samurai's/sierras the carrier is is smaller and bearing journals are also smaller.
Fancy drawing up a list?
  • Rockwatt
30 Jan 2016 09:32 #161479 by Rockwatt
Replied by Rockwatt on topic Re:RE: SJ Vitara Jimny diff compatibility.
If you ask a specific question then I'm happy to answer but I simply don't have time to do a complete breakdown sorry .
30 Jan 2016 09:47 #161480 by Busta
So Rockwatt, from what you did with Dave's LSD it seems with a machined Jimny front crown wheel and 26 spline half shafts the larger diff carriers can be fitted into the front axle?
Is there any way to fit a lock right in the front and keep 22 spline half shafts? I'm guessing not without machining new side plates for the diff.
Time to create page: 0.085 seconds
