Rev Limit
  • gus2000
10 years 9 months ago #161227 by gus2000
Replied by gus2000 on topic Rev Limit
Red injectors 180 cc/min
green injectors 220 cc/min
ratio green/red = 1,22
ratio g16b/g13b
1590cc/1298cc = 1,22
:) :) :) perfect
when G13B engine is replaced for the G16B engine , red injectors should be replaced by green.
  • saboor73
10 years 9 months ago #161555 by saboor73
Replied by saboor73 on topic Rev Limit
GraphicX wrote: from what i understand the 1.6 cam has a longer duration for opening the valves due to the longer stroke, but it should still rev pretty well just not as gutsy.
what injectors did you use ? the type that are most successful are the green injectors found in suzuki balenos which also have the 1.6 & look identical to those of the jimny except for the colour. from all the reading i did prior to swapping to the 1.6 no other injectors will give satisfactory performance, especially those that have the fatter body & i think some metal in the body as well.
M13a,m15a and m16a share same head design and m16a sport & m18a shares same head design cam of m16a and m13a are same
  • saboor73
10 years 9 months ago - 10 years 9 months ago #161557 by saboor73
@op both m13 and m16a (actually all m series engine) can only rev 6.5k rpm rev limiter can be removed your old moter rev limited might not be working other wise 7.5k rpm is not possible
Last edit: 10 years 9 months ago by saboor73.
  • GraphicX
10 years 9 months ago #161613 by GraphicX
Replied by GraphicX on topic Rev Limit
@ saboor; he's using a G series engine (vitara/baleno).
  • saboor73
10 years 9 months ago #161627 by saboor73
My bad :(
10 years 9 months ago #161663 by Lambert
Replied by Lambert on topic Rev Limit
My 2010 m13a redlines at just over 6500 rpm and is completely factory spec?
Time to create page: 0.095 seconds
