aprroximate labour time to fit lift kit? Simple?
- oxford_bloke
18 Nov 2010 10:43 #6078
by oxford_bloke
Replied by oxford_bloke on topic Re: aprroximate labour time to fit lift kit? Simple?
Are you sure there not spanners to stop the shock spinning when you tighten up the nut onto the mount. hence why you get the square bit at the top of the thread on the shock
Tom
Tom
- biggaz
18 Nov 2010 13:27 #6092
by biggaz
Replied by biggaz on topic Re: aprroximate labour time to fit lift kit? Simple?
Tom,
No mate, there too wide for that, i did think that at first
Adamski, yeh mate, ive fitted the ones which are just shorter after reading about what i said
Just hope them rear shock re-loaction brackets nip in a bit cos there miles wider lol.
- Adamski
18 Nov 2010 17:32 #6108
by Adamski
haha dont worry, mine were also too wide. When you tighten the nuts they just bend the brackets till they become tight. You may find that the shock bushes are a little wide for the Jimny mounts. I had to grind all mine down to get them to fit, except the ones in the rear shock relocation brackets
Replied by Adamski on topic Re: aprroximate labour time to fit lift kit? Simple?
biggaz wrote: Just hope them rear shock re-loaction brackets nip in a bit cos there miles wider lol.
- biggaz
18 Nov 2010 21:08 #6124
by biggaz
Cheers mate, ill have the grinder at hand lol!
Which panhards are you using, there all so bloody expensive!
- Adamski
20 Nov 2010 11:30 #6177
by Adamski
I've got the adjustable panhard rods from KAP. Cost just over £200 for the pair and due to the dodgy bushes, have given me problems since I've had the car on the road, sorted now tho
biggaz wrote: Cheers mate, ill have the grinder at hand lol!
20 Nov 2010 11:39 - 20 Nov 2010 11:42 #6179
Replied by mlines on topic Re: aprroximate labour time to fit lift kit? Simple?
Hmm, my modified panhard rods are £75 per pair on an exchange basis.
You would have to add the cost of bushes and P+P on top.
As you may be aware - the bushes are causing me problems as well which is why they are not in the shop at present. If anyone wants this done and are willing to sort the bushes themselves then let me know.
The way is works is I have a pair of rods here already. When you are ready you send me the money and I get the rods made up. Then when they are ready we arrange to swap your old rods for the extended ones. This way you are not sitting around with the car in bits. However you should note that using this method you DO NOT get your own old rods back, hence (at present) you get either get an old set of someone elses bushes or even no bushes at all. For example the set of rods I have here today have no bushes in the front rod.
If you want this done to your own existing rods then you would have to plan to have around 3 weeks with yout Jimny in bits.
Bit of info here:
www.bigjimny.com/index.php?option=com_co...cellaneous&Itemid=37
Bit of info here:
Last edit: 20 Nov 2010 11:42 by mlines.
Time to create page: 0.529 seconds
