aprroximate labour time to fit lift kit? Simple?
  • Adamski
17 Nov 2010 14:53 #6030 by Adamski
biggaz wrote: Also those funny shape fork brackety type things lol, what they for?
When you say funny shape fork things, do you mean these:
If so, these are shock re-positioners which fit on the bottom of the rear shock absorbers allowing more movement of the rear shocks. They twist the shock by 90 degrees giving the shock an extra plane of movement. See below:
  • mcjimny
17 Nov 2010 16:22 #6035 by mcjimny
biggaz wrote: Yeh thats what im most bothered about to be honest, those bloody bleed nipples!
They're made of such soft metal its not hard to be a bit over zealous and snap one off inside the cylinder. They're not dear so easier to swap it than try to get the bust bit out.
I've learnt my lesson..................twice :blush:
  • biggaz
17 Nov 2010 16:37 - 17 Nov 2010 16:38 #6037 by biggaz
naa mate, like almost a crap looking spanner haha, may be obvious when fitting the kit i dunno but i have no idea at the minute?
Got one with each shock and 5 sleeves with EACH shock, are the different sleeves just for different fitments on other vehicles, like use the best one for yours????
These things!
Attachment IMAG0102.jpg not found
Last edit: 17 Nov 2010 16:38 by biggaz.
  • Adamski
17 Nov 2010 16:54 #6041 by Adamski
biggaz wrote:
These things!
I'm not 100% sure however at a guess I would say that it is to relocate the brake balance spring on top of the rear axle back to where it should be following the 3" lift.
I made one of these last week for mine, however it didn't look like that. Take a look at this thread for more info and photos.
  • biggaz
17 Nov 2010 16:59 - 17 Nov 2010 17:01 #6042 by biggaz
you know what, after looking at that link i think your right, cheers for that, much appreciated!
Well i have four lol so if it works then i have spares if someone needs one!
Oh and they are just over 3" long ;)
One more question, the sleeves..... should i fit the one thats flush with the edge of the bush, just after reading your panhard trouble....
Last edit: 17 Nov 2010 17:01 by biggaz.
  • Adamski
17 Nov 2010 21:33 #6064 by Adamski
biggaz wrote: you know what, after looking at that link i think your right, cheers for that, much appreciated!
No problem B) . Do you have any sleeves that are just slightly shorter than the actual bush??
