split charge relay
  • TomDK
21 Dec 2015 12:07 #158908 by TomDK
Replied by TomDK on topic split charge relay
S200KYS wrote: There is a reasoning I've read somewhere on the internet (Difflock?) somewhere Tom that two linked batteries will try and top each other up?
i.e. one battery has less charge than the other, so they will equalise by the higher charged battery passing some charge to the other, etc, etc, and they will eventually deplete each other.
If they are linked by a relay this will not happen, as they are not physically linked until the engine is charging the batteries...
That is correct if you use 2 different batteries.
Which is why I also always recommend using 2 identical batteries.
2 good quality AGM batteries 70-90 Ah each is more than sufficient for powering almost anything.
I'd say a split charge relay is only necessary if you ever decide for longer trips to remote desolate areas. Like Asia, Eastern europe, Africa and such.
  • rexthecat
21 Dec 2015 19:04 #158923 by rexthecat
Replied by rexthecat on topic split charge relay
Thanks, T max system does look good, handy you get the read out too. Cheap has its benefits too! Think I'll see how the pennies are looking in Jan.
Cheers
Time to create page: 0.077 seconds
