split charge relay
  • rexthecat
10 years 10 months ago #158836 by rexthecat
split charge relay was created by rexthecat
Anyone done a split charge system using a voltage sensitive relay....just wondering anything to look out for etc, any recommendations?
Was thinking putting second battery secured over the wheel arch in the back with an inverter. Easy access for running tools from etc, no seats or plastic in the back now and got a compressor under the bonnet where a 2nd battery may go otherwise.
Battery wise do I need to get a battery similar the starter battery or not important?
Cheers
10 years 10 months ago #158837 by facade
Replied by facade on topic split charge relay
You need a leisure battery, these are designed to be discharged down to around 40% of capacity without damage, (starter batteries are not happy losing more than 10% or so) but they are heavy (presumably due to the better construction) and you won't see many with more than 12 months guarantee.
I suppose you could get a starter battery with a 5 year guarantee, and take it back every 12 months or so ;)
With a voltage sensing relay, the auxiliary battery is isolated from the starter battery at cranking, so you only need cable it with power amplifier cable to the back 8GA will take 75A, you might get away with 10GA.
  • X8GGY
10 years 10 months ago - 10 years 10 months ago #158838 by X8GGY
Replied by X8GGY on topic split charge relay
Mine...
I run a Bosch Battery as the engine battery, and an Odyssey PC1200 deep cycle winch battery as the auxiliary, these are linked by a T-Max split charge system from JimnyBits - in the yellow square on the photo, this also gives a useful battery readout of both batteries on the dashboard.
I also have a manual switch - red circle on the photo - to manually connect the two batteries if I ever need to (using full size winch cable as well, not the thinner charging cable supplied with the T-Max kit)... i.e. if I need to jump start the Jimny off it's own second battery... there is an option to do this on the T-Max control panel, but it only works if you have some charge in the main battery. The manual switch can also be used to give alternator power to the winch(es) if the auxiliary battery ever got depleted...
My auxiliary battery runs both winches and all the extra lighting and horns, etc, to save the engine battery taking the additional load...
The Odyssey battery is sat in a JimnyBits ABS model battery tray.
The switch 'bridge' across the engine bay also contains battery-type isolation switches for the front (you can see the red 'key' in the photo) and rear winches, a front winch wander-lead connector (there are remote switches for both winches on the dash), the T-Max split charger, and an auxiliary fuse box and the relays for the front light bar and extra horns.
Last edit: 10 years 10 months ago by X8GGY.
  • X8GGY
10 years 10 months ago - 10 years 10 months ago #158839 by X8GGY
www.jimnybits.co.uk/shop/electrical/t-ma...system/prod_276.html
That's the split charge I used, but it came with a better dashboard display -
That's it on the left there, and on the right you can see the winch switches, each has an "aircraft" yellow switch that has to be "ON" before the in / out rocker switch will work, to stop them being pressed by mistake...
  • TomDK
10 years 10 months ago #158887 by TomDK
Replied by TomDK on topic split charge relay
rexthecat wrote: Anyone done a split charge system using a voltage sensitive relay....just wondering anything to look out for etc, any recommendations?
Cheers
Are you sure you actually need a split charge relay?
I like to keep things simple.
Running a twin motor Warn 8274 with 2 Varta 80 CCA 80 Ah batteries and have never ever had even the slightest problem cranking the engine if it's stalled during winch challenge after long winch pulls and such.
  • X8GGY
10 years 10 months ago #158904 by X8GGY
There is a reasoning I've read somewhere on the internet (Difflock?) somewhere Tom that two linked batteries will try and top each other up?
i.e. one battery has less charge than the other, so they will equalise by the higher charged battery passing some charge to the other, etc, etc, and they will eventually deplete each other.
If they are linked by a relay this will not happen, as they are not physically linked until the engine is charging the batteries...
Time to create page: 0.095 seconds
