Speed sensor wire?
  • Funky Diver
02 Dec 2015 22:34 #157756 by Funky Diver
Replied by Funky Diver on topic Speed sensor wire?
It should be fine. It's only reading the sensor data, presumably for volume control?
  • Gerula
03 Dec 2015 00:32 #157761 by Gerula
Replied by Gerula on topic Speed sensor wire?
It's a GPS unit, apparently it needs the data to calculate speed in areas where GPS signal cannot be received.
  • mickt
03 Dec 2015 11:13 - 03 Dec 2015 11:28 #157776 by mickt
Replied by mickt on topic Speed sensor wire?
Good info funky driver. I have the disc with the electrics on it and have located the drawing with the connecters on it and the section showing the connectors but there does not seem to be an actual circuit diagram showing the wires and where they go to!
Further reading and I have found the circuit it is C1 combination meter and is as Funky driver says yellow/green seems to go to the speedo.
Last edit: 03 Dec 2015 11:28 by mickt. Reason: correction to text to clarify
  • Funky Diver
03 Dec 2015 16:57 #157792 by Funky Diver
Here you go, the circuit diagram. VSS is the bit of kit you are connecting into.
Time to create page: 0.086 seconds
