Speed sensor wire?
  • Gerula
10 years 11 months ago #157713 by Gerula
Speed sensor wire? was created by Gerula
I'm about to install an old Alpine head unit into the Jimny and I need to connect it to the speed sensor of the car. Is there such a wire/plug somewhere in the early Jimny's dash? (mine is a 98)
I'd rather not mess up with the ECU (as in using the speed sensor pin in the ECU plug to tap a wire and so on) :)
10 years 11 months ago #157717 by j999pre
Replied by j999pre on topic Speed sensor wire?
Speedo is fed from the speedo sensor on the transfer case
Grey pick up Jimny
  • Gerula
10 years 11 months ago - 10 years 11 months ago #157724 by Gerula
Replied by Gerula on topic Speed sensor wire?
Thanks. Is there any wire somewhere in the dash or I need to run one from the sensor?
From what I gather the one wire that needs to be connected to the head unit is a pulsed ground that is fed to the ECU so I need to do a proper job with the identification. :)
Apparently this is how the connector on the transfer case looks like (not sure if there's only one model). Anyone familiar with the pinout? :)
Last edit: 10 years 11 months ago by Gerula.
  • mickt
10 years 11 months ago #157736 by mickt
Replied by mickt on topic Speed sensor wire?
I have had a look on the cd's of the Maintenance manual but the circuit is not shown unfortunately as far as I can make out.
  • Funky Diver
10 years 11 months ago - 10 years 11 months ago #157741 by Funky Diver
Replied by Funky Diver on topic Speed sensor wire?
Yep same here... except it's part of the floor circuit ... L19 is the connector for Vehicle Speed Sensor.
It should be the Yellow with the green trace entering the Speedo.
Link to wiring diagram - you should be able to download it
Last edit: 10 years 11 months ago by Funky Diver. Reason: Added link
  • Gerula
10 years 11 months ago #157755 by Gerula
Thanks :) . I'm guessing it would be safe to make an Y junction on it before it enters the instrument cluster, right?
Time to create page: 0.105 seconds
