Overheating after using k-seal
  • WillFindlay
20 Sep 2015 14:00 #152287 by WillFindlay
Overheating after using k-seal was created by WillFindlay
Had been loosing a small amount of coolant from the cooling system so used a bottle of k-seal to solve this issue which it did. The engine now however is running extremely hot all the time
  • Statey
20 Sep 2015 16:25 #152291 by Statey
Replied by Statey on topic Re:Overheating after using k-seal
Where was the leak? I found a hole that had been plugged up in the middle of my radiator causing overheating. I've also used K seal for a leak near the water pump and had no issues since :)
20 Sep 2015 18:07 #152295 by X8GGY
Start with the thermostat then?...
Could be clogged / fur'bared...?
  • helijohn
20 Sep 2015 18:32 #152301 by helijohn
Replied by helijohn on topic Overheating after using k-seal
I have used K seal many times and never had a problem but I have used others like rad weld which clumps up and creates potential blockage. Having said that for a small rad leak problem I swear by Bars leaks. ;) K seal has been very effective for me. B)
20 Sep 2015 19:07 #152307 by Rhinoman
Is it possible that the leak allowed air into the system? it may just need bleeding.
20 Sep 2015 19:40 #152309 by skywalker65
Surely if you've got a leak somewhere it's better to fix it correctly than chuck something that when all said and done is nothing more than a bodge
If in doubt ...... Flat out ??
Time to create page: 0.162 seconds
