Overheating after using k-seal
- WillFindlay
20 Sep 2015 14:00 #152287
by WillFindlay
Overheating after using k-seal was created by WillFindlay
Had been loosing a small amount of coolant from the cooling system so used a bottle of k-seal to solve this issue which it did. The engine now however is running extremely hot all the time
- Statey
20 Sep 2015 16:25 #152291
by Statey
Replied by Statey on topic Re:Overheating after using k-seal
Where was the leak? I found a hole that had been plugged up in the middle of my radiator causing overheating. I've also used K seal for a leak near the water pump and had no issues since
- X8GGY
20 Sep 2015 18:07 #152295
Replied by X8GGY on topic Overheating after using k-seal
Start with the thermostat then?...
Could be clogged / fur'bared...?
20 Sep 2015 18:32 #152301
Replied by helijohn on topic Overheating after using k-seal
I have used K seal many times and never had a problem but I have used others like rad weld which clumps up and creates potential blockage. Having said that for a small rad leak problem I swear by Bars leaks.
K seal has been very effective for me.
20 Sep 2015 19:07 #152307
by Rhinoman
Replied by Rhinoman on topic Overheating after using k-seal
Is it possible that the leak allowed air into the system? it may just need bleeding.
- skywalker65
- Premium Member
- Thank you received: 20
20 Sep 2015 19:40 #152309
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic Overheating after using k-seal
Surely if you've got a leak somewhere it's better to fix it correctly than chuck something that when all said and done is nothing more than a bodge
Time to create page: 0.098 seconds
