Front end squeel
08 Sep 2015 21:12 #151562 by Casey
Front end squeel was created by Casey
Front end started squeeling intermittently (seems worse when cold or wet) so had both belts replaced but hasn't solved the problem.
Have read in other posts that the alternator bearing can make a squeal that sounds like the belt.
Anyway, just thought I'd ask for advice before replacing it.
When the squeal starts I can get rid of it sometimes by switching the ignition off and on again. When it starts making a noise it stops when I put the clutch in. I'm not getting a battery light up and all the electrics seem fine.
Have sourced a second hand alternator for £60 delivered. Is this reasonable and is this likely to be the problem?
08 Sep 2015 21:20 #151563 by j999pre
Replied by j999pre on topic Front end squeel
Could be water pump or power steering pump or and idler/tensioner or a slack belt.
Take the belts of and check rotating components
If it is alternator I can do a used one for £40 delivered
Is yours an m13a or g13b engine?
Grey pick up Jimny
The following user(s) said Thank You: Casey
08 Sep 2015 21:27 #151564 by Casey
Replied by Casey on topic Front end squeel
Thanks for the super fast response. I'll take your advice and check they're rotating OK. £40 is sounding good so if it's looking like that's the problem I'll take you up on that. Cheers
  • Statey
11 Sep 2015 20:55 #151777 by Statey
Replied by Statey on topic Re:Front end squeel
J999pre I think has it spot on! Plus he's always got bits :) I've had a few bits off him
  • gilburton
12 Sep 2015 09:59 - 12 Sep 2015 10:03 #151791 by gilburton
Replied by gilburton on topic Front end squeel
Wait a minute he did say it stops when he puts the clutch in??
Release bearing??
Check clutch cable adjustment as well before delving in to alternators etc.
Last edit: 12 Sep 2015 10:03 by gilburton.
12 Sep 2015 12:47 - 12 Sep 2015 12:49 #151806 by Casey
Thanks.
I haven't had chance to take any belts off yet, but your suggestion about the clutch would seem to make sense. After all if it was associated with one of the pulley driven bits why would it stop when the clutch is depressed?
How difficult is it to adjust the clutch, if it's the release bearing would adjusting the clutch make a difference?
Last edit: 12 Sep 2015 12:49 by Casey. Reason: error
Time to create page: 0.106 seconds
