Front end squeel
11 years 2 months ago #151562
by Casey
Front end squeel was created by Casey
Front end started squeeling intermittently (seems worse when cold or wet) so had both belts replaced but hasn't solved the problem.
Have read in other posts that the alternator bearing can make a squeal that sounds like the belt.
Anyway, just thought I'd ask for advice before replacing it.
When the squeal starts I can get rid of it sometimes by switching the ignition off and on again. When it starts making a noise it stops when I put the clutch in. I'm not getting a battery light up and all the electrics seem fine.
Have sourced a second hand alternator for £60 delivered. Is this reasonable and is this likely to be the problem?
11 years 2 months ago #151563
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Front end squeel
Could be water pump or power steering pump or and idler/tensioner or a slack belt.
Take the belts of and check rotating components
If it is alternator I can do a used one for £40 delivered
Is yours an m13a or g13b engine?
Grey pick up Jimny
The following user(s) said Thank You: Casey
11 years 2 months ago #151564
by Casey
Replied by Casey on topic Front end squeel
Thanks for the super fast response. I'll take your advice and check they're rotating OK. £40 is sounding good so if it's looking like that's the problem I'll take you up on that. Cheers
- Statey
11 years 2 months ago #151777
by Statey
Replied by Statey on topic Re:Front end squeel
J999pre I think has it spot on! Plus he's always got bits
I've had a few bits off him
- gilburton
11 years 2 months ago - 11 years 2 months ago #151791
by gilburton
Replied by gilburton on topic Front end squeel
Wait a minute he did say it stops when he puts the clutch in??
Release bearing??
Check clutch cable adjustment as well before delving in to alternators etc.
Release bearing??
Last edit: 11 years 2 months ago by gilburton.
11 years 2 months ago - 11 years 2 months ago #151806
by Casey
Thanks.
I haven't had chance to take any belts off yet, but your suggestion about the clutch would seem to make sense. After all if it was associated with one of the pulley driven bits why would it stop when the clutch is depressed?
How difficult is it to adjust the clutch, if it's the release bearing would adjusting the clutch make a difference?
Last edit: 11 years 2 months ago by Casey. Reason: error
Time to create page: 0.089 seconds
