Disconnected pipe.
11 years 2 months ago #150779
Replied by mlines on topic Disconnected pipe.
But there is a small reservoir so the system will still actuate if the engine has stopped after the reservoir has "filled" with the vacuum (if you see what I mean!)
The following user(s) said Thank You: Casey
11 years 2 months ago #150982
by kirkynut
Replied by kirkynut on topic Disconnected pipe.
With vacuum pipes that bad I would forget the vacuum system and either go for fixed hubs or manual ones and pick what info suits your choice from this guide I wrote:
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=55862
The photos will help I hope.
11 years 2 months ago #151392
by Casey
Replied by Casey on topic Disconnected pipe.
With the use of this fantastic guide
www.bigjimny.com/index.php/information/q...ask=weblink.go&id=53
I used a piece of clear plastic windscreen washer tube. Cleaned the two solenoids/valves and bingo working hubs.
Thanks to everyone for their replies.
Time to create page: 0.088 seconds
