front drive engaging?
50 mmHg = 6.66611842 kilopascals. I had a search about for front hub vacuum seals, but can't seem to see anything anywhere. Perhaps I'm not using their correct/technical name.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Remove the black freewheel unit, and blow through the two vacuum ports on the hub to check that they are not blocked.
If there is free passage through all 4 of them, you will have to check that one or both hubs haven't had the pipes crossed over,
facade wrote: If someone has changed a wheel bearing, the vacuum port in the hub is usiually blocked with grease, and the hubs won't work.
I gave the vacuum ports a good air blasting and prodding with a wire, but couldn't see any difference and I've checked the correct hose is operating, at the hub. Hopefully I'll find out if the port is the problem once I get a vacuum on it. It could be that the mating between the hub port and the pipe is worn.
I'll convert to pressurised operation sometime in the future.
Pull both hub lines from the solenoids (they point to the rear) make sure they have no vacuum leaks there.
Keithy wrote: I kind of like my vacuum hubs.....I keep having problems with dirt ingress keeping the upper solenoid open though.
Pressurised option? Do you mean the manual hubs? I'm not keen on shifting to those just yet. Cost is the first reason and secondly, I don't really want to get my feet wet changing to 4WD
I've confirmed that there's a vacuum present down tot he hubs, but I can't confirm if they are correct pressures as I don't have means of measuring the vacuum pressure. I'll find out when some kit I've ordered arrives. Hopefully before the weekend.
- auchenblae
- Elite Member
- Thank you received: 25
On the nearside one it engages at 10kPa and takes 40Kpa to disengage.
That is with putting the pump on to the hub nipples, top to engage front middle to disengae
On the offside the pump holds 50kpa but the hub does not engage.
If I manually put the autohub in 4WD and put it back on with 40kPa it makes an effort to disconnect via the front side nipple.
I assume I have grease in one or both of the vacuum tubes in the offside hub so wil have to clean it out.
The vacuum pump them went faulty!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
