front drive engaging?
01 Jun 2015 17:20 - 01 Jun 2015 17:27 #145236 by Mike G
front drive engaging? was created by Mike G
Gents,
I got stuck in the mud yesterday, I'm just not sure my front axle is doing anything. I can put the Jimny into 4wd and 4wd low range. I hear the clicks of engaging (things), but when I got out and watched my wheels spinning, only the rear wheels were doing anything.
The dash 4x4 light is steady green, no flashing. Is this a known fault or easily rectifiable situation?
Many thanks
I only ask as it's raining hard and blowing a gale outside and I don't really want to lay on the ground under the car tonight.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Last edit: 01 Jun 2015 17:27 by Mike G. Reason: extra
01 Jun 2015 17:33 #145239 by Mike G
Replied by Mike G on topic front drive engaging?
I've found one of Martins guides.
www.bigjimny.com/images/documents/Check_the_vacuum_system.pdf
Think I'll have a read of that tonight.
01 Jun 2015 20:13 #145260 by j999pre
Replied by j999pre on topic front drive engaging?
If it's clicking both sides and the light is solid should be working unless you have a damaged diff or cv etc or it has been piped backwards
Grey pick up Jimny
  • Grego
01 Jun 2015 20:23 #145263 by Grego
Replied by Grego on topic front drive engaging?
Put in 4wd, jack up a front wheel and turn the wheel to see if its locked. 2 mins if you have a trolley jack
01 Jun 2015 20:50 #145264 by Mike G
Thanks guys,
The weather is wet and very windy just now and probably will be for another day and as i don't have a garage or shelter to work on the car, I'm not that keen on getting soaking wet.
Interestingly enough, I was reading another article on the forum under the topic 'Drivers side Vacuum hub permanently locked?' and it mentions that some hissing was heard during the process of elimination. I have heard a similar hissing from my Jimny in the past and wondered what it could have been. It sounded like it was coming from the engine bay or passenger foot-well. At first I thought it was rumbling bearings on the water pump or something like that on the serpentine belts, but now it's clear that there's probably a leak somewhere on the vacuum lines for the hub engagement process.
Think I'll have a good look at the security and integrity of the air-lines when I get a chance (and the sun is out B) )
01 Jun 2015 22:51 #145274 by Busta
Replied by Busta on topic front drive engaging?
If you heard the hubs engage and the 4wd light was on but not flashing then it sounds like the vacuum system is working fine. If the vacuum system did have a leak, it would only start hissing when you selected 4x4 and would stop after 5-10 seconds. I very much doubt you would hear it from inside the car!
Just to make sure, you are aware that even when in 4x4, you may only have 1 wheel spinning on each axle? So if you looked at the drivers side wheel and it wasn't spinning, the drive would have all been going to the passenger side wheel.
Time to create page: 0.103 seconds
