Fault code reader
- imtherobster
11 years 6 months ago #143706
by imtherobster
Replied by imtherobster on topic Fault code reader
Seen so many complaints about those clone readers, do they actually do the job intended?
I have also seen the ones on the sealey web site, For £149 with updates and data print out options. Anyone have experience with these mid range but quality readers/code re-setters?
11 years 6 months ago - 11 years 6 months ago #143708
by Rhinoman
Replied by Rhinoman on topic Fault code reader
The Chinese clones are usually quite reliable. Updates aren't generally much use, the OBD spec rarely changes and by the time it does the tool probably won't be supported anymore. Many of the cheap tools have a serial connection so data can be downloaded to a PC.
The Sealey tools are made by Autel and can be sourced cheaper elsewhere.
Last edit: 11 years 6 months ago by Rhinoman.
The following user(s) said Thank You: imtherobster
11 years 6 months ago #143720
by facade
Replied by facade on topic Fault code reader
I have a Chinese clone of an Autel Maxiscan MS509.
These are available on eBay for about £30. (They claim to be genuine :woohoo: )
However the one that the Chinese copied was faulty, and
1) if you fit a battery inside they fail instantly- so don't
2) they won't update via the USB cable. (despite coming with all the software :whistle: )
The USB does power it up, so you can look at the freeze frame data in the house.
Apart from that, they are extrememly good value for money.
The next step up is something like the Launch creader, the price will make your eyes water though, that can reset codes on the ABS and airbags of Other Cars.
11 years 6 months ago - 11 years 6 months ago #143820
by kirkynut
Replied by kirkynut on topic Fault code reader
I use a scangauge 2 in my Fiesta and used it in my Ignis so I know it'll work in a Zuke.
It has the benefit of being a gauge showing useful info like coolant temperature so you know if it's getting hot for any reason. The dash temperature gauge is rubbish.
It also is a code reader and clearer.
There's cheaper bluetooth versions but I like the scangauge.
www.amazon.co.uk/ScanGauge-II-Fuel-Compu...XGauge/dp/B000AAMY86
I run a maxi trip version in my Jimjam like Martin has but they appear to have gone out of business.
How about this for a straight forward code reader: www.amazon.co.uk/Mbuynow-MaxiScan-MS309-...Reader/dp/B00F3V9MYG
Last edit: 11 years 6 months ago by kirkynut.
- imtherobster
11 years 5 months ago #145085
by imtherobster
Bought one of the MaxiScan 309 code readers, it appears to be a chinese non working clone so I am currently in dispute with the seller. As we have enough cars in the family circle to make buying a decent one worth while, think i might go for a better model/supplier this time.
Seems loads of people have had the same issues with these so called Autel clones, Autel have never made these models so it appears they are all fakes. You may get lucky and find a working clone amongst them, but I'm not the lucky sort it seems.
Will let you know how I get on with a better model
11 years 5 months ago #145091
by facade
If you want to splash out, and have a fleet of Modern Cars, have a look at the Launch
www.launchtech.co.uk/ do not buy one from anyone else (they are miles cheaper on Amazon/eBay), as the serial won't be recognised, and it won't update.
The CRP123 & CRP129 are good, but frighteningly expensive when you put them against the clones, but you are paying the people who actually develop the software, not pirate it.
(the 129 will reset the service light on a few vehicles, reset the steering angle sensor (my Other Car has one, and The Manual says to reset it pretty much every time you take a wheel off) and set the electronic parking brake if you are unfortuanate enough to have a Renault, or RangeRover with one. Other than that and the 129 having a record mode that no-one can work they are the same)
Time to create page: 0.104 seconds
