Fault code reader
  • imtherobster
11 years 6 months ago #143526 by imtherobster
Fault code reader was created by imtherobster
Hello Big Jimny
Daughter has bought a 2001 Jimny recently through a private purchase which I did not get a chance to check over thouroughly.
It has a few problems, which I can handle following the guides here on your web site, but has now come up with an EM lamp on the dash.
The engine is running fine still, no change in idle, so guessing its an emmissions sensor, or the like.
Does anyone have experience with a reliable code reader for the jimny, which also has the ability to reset em alarms etc.
I look forward to your response
  • X8GGY
11 years 6 months ago #143527 by X8GGY
Replied by X8GGY on topic Fault code reader
Welcome imtherobster ;)
Rhinoman's your man... he'll be along soon B)
Dave
11 years 6 months ago #143545 by Rhinoman
Replied by Rhinoman on topic Fault code reader
You need to check the diagnostic plug under the dash and see which pins are populated. If you have pin 7 populated then you can use a generic scan tool, if not then you need an SDL interface. Pin numbers are shown here:
www.rhinopower.org/diag/sdl.html
  • helijohn
11 years 6 months ago #143548 by helijohn
Replied by helijohn on topic Fault code reader
Rhinoman wrote: You need to check the diagnostic plug under the dash
PM sent
  • imtherobster
11 years 6 months ago #143632 by imtherobster
Replied by imtherobster on topic Fault code reader
Managed to take a picture of the port, and appears to be an OBD2 port. Any suggestions regarding a decent tool to work with this, or even better one that will work with many different makes and models.
  • helijohn
11 years 6 months ago #143637 by helijohn
imtherobster wrote: Managed to take a picture of the port, and appears to be an OBD2 port. Any suggestions regarding a decent tool to work with this, or even better one that will work with many different makes and models.
I suppose it depends what you want but the basic Chinese clone one suits me that you find on eBay for under 20 notes.
