Uh Ohhhh!
  • Nate83
14 Feb 2015 14:43 #137917 by Nate83
Uh Ohhhh! was created by Nate83
Hey guys.....
after fitting a 2" spring spacers and 32mm wheels spacers i went about getting new wheels........i bought a set and was told that they would fit my jimny even without the lift........Wrong! the back fit okay with a little room for negotiation but the fronts seem to be way to huge,catching on the front and the back of the arch.
The wheels are 235/75/15 with off road tyres...without having to cut the hell out of stuff is there an alternative way to get these on? iv'e heard of people running these size wheels and tyres with no issues,thanks in advance
  • suzukisam
14 Feb 2015 14:47 #137918 by suzukisam
Replied by suzukisam on topic Uh Ohhhh!
I run same set up as you even have a 2 inch body lift but still had to cut front arches to suit .
Also trimmed back ones slightly but i made the inner arches to fit still to save mud coming into door shuts
  • Nate83
14 Feb 2015 15:00 #137922 by Nate83
Replied by Nate83 on topic Uh Ohhhh!
Hi sam would a 3" body lift do the trick? to be honest i'll probably end up selling them and going for a smaller tyre...what would you recommend with the current lift n spacers? i just want to beef the truck up a bit
14 Feb 2015 15:45 #137925 by funkyjimny
Replied by funkyjimny on topic Uh Ohhhh!
Dave Jones has these size tyres on with no rubbing and no cutting, probably got equal to a 3.5" spring lift as his is weighed down with lots of steel bits! I think the secret to getting them to fit is putting them on narrow wheels, Dave has them on standard vitara wheels which have a bit less offset than Jimny wheels. If you find his thread 'vitara dave' is his username or look on www.bits4vits.co.uk then 'read our blogs' top left there's a full write up of his car which must mention the wheels/ tyres
Gary
The following user(s) said Thank You: Nate83
  • Nate83
14 Feb 2015 15:59 #137926 by Nate83
Thanks gary,apparently these are vitara wheels,i'm not 100% though but thanks for the advice
  • X8GGY
14 Feb 2015 16:13 - 14 Feb 2015 16:19 #137927 by X8GGY
Replied by X8GGY on topic Uh Ohhhh!
Yup, as Gary says, I've got 235/75/15 Malatesta Kobra remoulds (edit: same as your judging by the photies) on Vitara rims with 30mm wheel spacers and a 4" spring lift, no body lift, no rubbing B)
Hmmm, thinking about it though, as part of my lift I have ORA radius arms... they presumably position the axles / wheels better in the arches too?...
Last edit: 14 Feb 2015 16:19 by X8GGY.
Time to create page: 0.099 seconds
