Uh Ohhhh!
- Nate83
14 Feb 2015 16:59 #137930
by Nate83
Replied by Nate83 on topic Uh Ohhhh!
Hi Dave that's a cracking looking jimny mate,yes i have the same tyres...i see you've modded your bumpers...is tha for off road purposes only?
Also how did you achieve the 4" lift? iv'e yet to find a 4" kit only 2"/3" plus will i need correction bushed so on?
kind of blew what was left of my budget on the wheels and tyres
14 Feb 2015 17:49 #137936
by Busta
Non-remould 235/75 R15s may fit, such as BFGoodrich, Kumho or Generals. Remoulds tend to be an inch or so taller. They are also horrible on the road!
A safer bet is going for some 215/75 R15 or 195/80 R15.
- Nate83
15 Feb 2015 08:37 - 15 Feb 2015 08:38 #137985
by Nate83
No eBay APP ID and/or Cert ID defined in Kunena configurationThanks guys,i checked last night there' s no markings on them to suggest the width but i assuming looking at them they gotta be at least 9j,i can't open my thumb and middle finger and touch both ends of the tread.
if i can sell these i was looking at a 205/70/15 off road tyre like below
would a 215/75/15 be a better fit or 195/80/15?
Thanks again
Thanks again
Last edit: 15 Feb 2015 08:38 by Nate83. Reason: grammer
15 Feb 2015 11:32 #137994
by Busta
I use
THIS SITE
to compare tyre sizes.
205/70 is the standard tyre size. 215/75 or 195/80 offer a bit more ground clearance and will fit without trimming.
If you intend to use this Jimny as your daily driver I would avoid re-moulds! Yes they are cheap, but you could get a decent set of all-terrains for not much more which will still look good, handle a lot better on the road, be much quieter and last a lot longer!
15 Feb 2015 13:15 - 15 Feb 2015 13:16 #138000
by dirtydogz
2002 JLX Soft Top
Have you tried fitting the wheels and tyres with out the wheel space's first.
2002 JLX Soft Top
Last edit: 15 Feb 2015 13:16 by dirtydogz.
Time to create page: 0.209 seconds
