Best way to get more power is...?
Drop it down a gear or 2 for overtakes and hills. 3rd is good for 70mph, so great for passing lorries.
MysticRich wrote: This is always a good topic :S
So what happens when you've fitted the 1.6 and 4branch ect and still want more power !!
Is it really worth the expense of a high lift cam and head work for the possible gains ???
I priced up a set of cams at over £700 and they recommend changing valve springs ect which is all extra cost then it needed a remap to run so another £500+ and while head is stripped you might as well get that done so a couple more hundred for a few bhp ???
You need another engine swap! This time to something more powerful and tuneable out of the box.
The Mk3 Mazda MX5 engine and gearbox would be a good option. The 2.0l makes 160hp. The 5 speed gearbox will be easier to fit than the wider 6 speed. You are looking at £2k by the time you get an engine, gearbox and ECU to run it all, but that's more power than you'll ever get out of the Suzuki 1.6.
There are loads of other options though for light weight, high output engines that have RWD gearboxes readily available- Rover K-series, Ford Duratec, Sigma or Ecoboost, any BMW 4cyl, Mazda RX8 rotary. It's just a case of how much you want to spend and how much work you want to put in.
- TomDK
- davert85
If its a possible question to answer whats the cost of a 1.6 swap (parts, labour, time etc?)
Thanks
It'll bump your insurance up a bit but other than that it's all winning!
