Best way to get more power is...?
27 Jan 2015 16:56 #136154
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Best way to get more power is...?
Yes they aren't bad to do I've done 5!
Grey pick up Jimny
The following user(s) said Thank You: davert85
- Walkerc
27 Jan 2015 18:25 #136168
by Walkerc
Replied by Walkerc on topic Best way to get more power is...?
Weight is the killer on the power, my Jimny is nice and light so it's pretty nippy considering the only modification engine wise is the exhaust. Gearing also makes a difference, certainly helps it pull away quicker.
28 Jan 2015 10:25 #136247
by safari
if u worry u die if u dont worry u still die so why worry
Replied by safari on topic Best way to get more power is...?
hi what exactly is needed ,like do the engine mountings match or new brackets needed . i think new silenser and is any flange needed for gearbox tksj999pre wrote: Yes they aren't bad to do I've done 5!
28 Jan 2015 12:24 #136257
by j999pre
The g series is more involved gearbox adapter, engine mount plus a few other bits
The m series is easiest bolts straight up
All depends which engine you have
Grey pick up Jimny
Grey pick up Jimny
- mooie4x4
29 Jan 2015 04:40 #136342
by mooie4x4
Replied by mooie4x4 on topic Best way to get more power is...?
Super charge it
Sd proformance do a bolt on kit
- troggy
29 Jan 2015 18:16 #136402
by troggy
Replied by troggy on topic Best way to get more power is...?
Put your right foot out
Then the road will show you what its all about
Medicine head! Rising sun
