engine advice please
  • Russ-41
11 years 10 months ago #135199 by Russ-41
Replied by Russ-41 on topic engine advice please
Also, I think he'll point out that you preferably want one with the coil packs on, and you will NEED the green injectors. You may have to fit the Jimny cam to.
The inlet, exhaust and ECU from the Jimny are all retained although if memory serves me correct you may have to modify the exhaust flange?? Not sure.
I've been doing a bit of research over the last few days, Just to keep it in mind when I'm digging about in scrap yards, if I ever stumble over one, I'll probably buy it just in case I want to do one :P
  • whittleos
11 years 10 months ago #135202 by whittleos
Replied by whittleos on topic engine advice please
thanks for the help guys . i was going to get one that looks identical to jimny engine . if i remember rightly there is a diffrance in the cam position sensor one having something like 3 pin other having 11 or something i could be well off with numbers here but sure its something like that . i have no problem doing odd mods if its worth doing but if its not a great gain ..thanks again for all replays
  • darthloachie
11 years 10 months ago #135207 by darthloachie
Replied by darthloachie on topic engine advice please
this is the age of engine you want
ebay number 301477050226
we put a 2003 g16b gv engine in our 2000 g13bb
  • whittleos
11 years 10 months ago #135211 by whittleos
thanks again for the replay and yea that is the engine i was going to go for as looked same and guessed it would have sump etc to cover diff aka axle on jimny .. with this engine above dose it still need a adapter plate ? could any body post some pics of that side of things as id be making everything my self i just like to have a idea of what im getting my self in for . and has the conversion made a good difference to the i have a t case transfer box in and 31 inch insa turbo special tacks on so as you can imagine it barley moves lol . 3rd 4th most straight roads
  • whittleos
11 years 10 months ago #135213 by whittleos
and mine is 1999 single cam g13bb engine . first gen i think if i am correct . id put a td back in but i did not like how much weight it put on front completely changed the drive of it was lot better for power and fuel but id rather have a nicer drive and cost bit more to be honest . and when say engine mount wants altered a bit to what do you mean ? any pics of this to please ? thanks again for your replays and help guys
  • suzukisam
11 years 10 months ago #135230 by suzukisam
Replied by suzukisam on topic engine advice please
251714888972 thats the engine i used and is cheap at that however you will need to swap sump ,oil pick up
351285844513 thats the conversion plate you need
only other thing to buy is a skinny stater motor from a vit
Those numbers are item numbers on ebay at present
Time to create page: 0.095 seconds
