engine advice please
- whittleos
11 years 10 months ago #135131
by whittleos
engine advice please was created by whittleos
hi . i have been looking into putting a engine into my jimny i put a 1.7 td engine in it but it blown it up since now its got its stock g13bb engine back in . i was just looking to see if i could put a 1.6 g16b engine in or is the bell housing a lot diff etc or would it pretty much plug in and play im guessing id need ecu to to fuel it correctly and imobilser etc or my thinking to far a head here . any help would be much appreciated thanks
- whittleos
11 years 10 months ago #135132
by whittleos
Replied by whittleos on topic engine advice please
also if its a bolt in job dose it have to come from a baleno or can it come from a grand vitara ? id of thought been same engine code etc the bell housing would be the same but again im not sure on any of this hence id like to ask for help :L if any body can shed some light please . thanks again .
- suzukisam
11 years 10 months ago #135137
by suzukisam
Replied by suzukisam on topic engine advice please
Im currently fitting a 1.6 into mine pretty much plug and play except if you buy a baleno engine like me you will have to change sump and oil pick up pipe and more than likely the camshaft pick up point ..
then just injectors, inlet, exhaust
May sound hard but its fairly simple and i have pics of the work i have done so could forward them on to you if needed.
As for the bell housing the 1.6 is slightly wider so you have to buy a conversion adaptor plate which i got from Rik at waterbabies 4x4 it was £80 collected and came with corrected engine mount too .
If you search on here for g16 conversion etc theres lots of step by step guides to help you through .
- whittleos
11 years 10 months ago #135175
by whittleos
no problem thank you for your replay and time . could you email me some pics to caddylove23@gmail.com .. and if i where to get the vitara engine would there be less to do or just same ? thanks
- suzukisam
11 years 10 months ago #135192
by suzukisam
Less work better to ask j999pre on here he just done one with a vit engine
- mickt
11 years 10 months ago #135194
by mickt
Replied by mickt on topic engine advice please
I have seen j999pre gar and he said you need a plate to be able to mate the 1.6 Vit. eng to the Jimny box. The offside eng mounting needs to be modified along with another on the nearside, alternator I think. He also fitted the 1.3 injectors but pm him and I am sure he will give you the full monty. He is very helpful and genned up on these cars.
Time to create page: 0.089 seconds
