Exhaust sensor
  • mickt
14 Jan 2015 19:03 - 14 Jan 2015 19:06 #135100 by mickt
Replied by mickt on topic Exhaust sensor
My engine is the 13bb and the two sensors, each with four wires, are fitted with disconnect plugs. The pre cat sensor is mounted in the manifold and its plug fits into the disconnect plug which is attached to the bracket mounted at the back of the head on the nearside. The connectors are coloured blue and is quite large. The post cat sensor sits at the rear of the cat on top and its lead connects to its disconnect plug and is mounted right next to the front one. It is coloured black. The cables then disappear across the top of the bell housing to the offside.
Hope that helps. I will add a photo tomorrow and try to trace where the loom goes to from the disconnect plugs.
Last edit: 14 Jan 2015 19:06 by mickt. Reason: Further info added
  • darthloachie
14 Jan 2015 22:22 #135126 by darthloachie
Replied by darthloachie on topic Exhaust sensor
Thanks guys
That's brilliant. - will have look at the weekend as its dark when I get home from work
  • mickt
15 Jan 2015 13:13 #135161 by mickt
Photos attached as promised. The colours of the plugs is different to what I thought though but you can see that on the pics. They seem to disappear into the loom shown along with the rest of the engine wiring. Hope this helps.
Time to create page: 0.087 seconds
