Exhaust sensor
- darthloachie
13 Jan 2015 16:54 #135019
by darthloachie
Exhaust sensor was created by darthloachie
This is a stupid question but where does the wire from the exhaust sensor on a 2000 jimny plug into the wiring loom
The exhaust manifold was removed when the engine swap was done and not plugged back in
Neither the local garage or an auto electrician can find where it should be plugged in
Where can I find the other half of the plug?
Thanks
Thanks
- suzukisam
13 Jan 2015 17:30 #135023
by suzukisam
Replied by suzukisam on topic Exhaust sensor
It plugs in round back near gearbox if thats any help ??
- mickt
13 Jan 2015 20:04 #135040
by mickt
Replied by mickt on topic Exhaust sensor
Which engine is it? I have a 2001 SOHC I can look at tomorrow if that will help.
- Johnniehec
- Thank you received: 56
13 Jan 2015 22:33 #135056
by Johnniehec
Replied by Johnniehec on topic Exhaust sensor
2000 M13a both sensors are plugged into their connectors together at the back of the engine in line with the rocker cover gasket just below the middle of the bulkhead
- darthloachie
13 Jan 2015 23:25 #135062
by darthloachie
Replied by darthloachie on topic Exhaust sensor
its now a G16b was a G13bb
a photo would be good if anyone can help
thanks in advance
thanks in advance
- GarlixMojo
14 Jan 2015 18:58 #135098
by GarlixMojo
Replied by GarlixMojo on topic Exhaust sensor
If you follow the main loom from behind your battery, it splits into a few tentacles one of which goes to your starter motor and another goes round the back of your engine block to a connector. This is the one you need to plug into.
I've tried to take a few pics but it's a bit tricky to get to as the Inlet Manifold is in the way. I managed to get my hand and phone behind the engine to take some.
The green connector on the first pic is from the lambda sensor on the exhaust and on the second you can see the red wire which goes back to that main loom I was on about
Hope it makes sense.
Tony
Tony
Time to create page: 0.106 seconds
