the right tools ?
05 Jan 2015 20:48 #134252 by Halford
Replied by Halford on topic the right tools ?
thanks guys ... great advice as ever ;)
so it's the 3 piece splitter and halford's off to Halfords :S
  • supergaz
05 Jan 2015 21:44 #134263 by supergaz
Replied by supergaz on topic the right tools ?
Been using the flexi head rachet spanners for at least 7 years and only every had to get the 13mm replaced as I use the 13mm constantly, they replaced it without problem. I use my tools hard being a garage equipment field service engineer and when Halfords tools have failed it's due to my miss use. To be honest Halfords tools are spot on for their lifetime warranty and price and the ease of exchange under warranty.
Halford, Pm sent.
  • idiotmobil
05 Jan 2015 22:18 #134269 by idiotmobil
Replied by idiotmobil on topic the right tools ?
supergaz wrote: Been using the flexi head rachet spanners for at least 7 years and only every had to get the 13mm replaced as I use the 13mm constantly, they replaced it without problem. I use my tools hard being a garage equipment field service engineer and when Halfords tools have failed it's due to my miss use. To be honest Halfords tools are spot on for their lifetime warranty and price and the ease of exchange under warranty.
Halford, Pm sent.
not dissing Halfords tools as have a lot my self just a few things do seam a little week ive broke a couple 3/8 ratchets now, I always thought Halfords are guarantied but only on none moving parts ie: spanners sockets etc but things like ratchets and ratchet spanners arnt, if so ive wasted abit of money replacing a couple bits as allways been told by the spotty kid behind counter that was the way they worked
  • supergaz
05 Jan 2015 22:38 #134272 by supergaz
Halford, Pm sent.
That's true moving parts are not covered, I have always been lucky and the spotty kids have replaced moving parts spanners and ratchet mechs, even been given the repair kits and especially 8mm hex sockets that I snap quite often. As usual the spotty kids are so dopey they replace parts that they really shouldn't :)
  • idiotmobil
05 Jan 2015 22:55 #134275 by idiotmobil
I mite have to go out this weekend and try and find one that will replace my ratchet again, I have replaced about 5 1/4 8mm sockets they allways round off or crack also I found the 3/8 breaker bar in the socket sets snap but seen they have now discontinued the old type and changed them,
  • mickt
06 Jan 2015 11:57 #134292 by mickt
Replied by mickt on topic the right tools ?
The ones you photoed are very easily broken, they are very brittle and do split the boots. If you loosen off the nut to the end of its thread and use a hammer or two and strike the arm the ball joint goes in they can just drop out, sometimes! I use this type ebay item number 110763406191 is an example. There is one for £11.29 posted. I have had mine years and it has never failed. The joint is a taper fit and some are tighter than others. Even using this type I have had to also use a hammer on the tool to shock the joint apart on some vehicles!
Time to create page: 0.111 seconds
