the right tools ?
- weeleejimny
Don't be put off by the word Hydraulic. It doesn't need an air compressor or any fancy machines. You make the large bolt hand tight on the top of the ball joint, then turn the smaller inner bolt which is connected to a piston at the other end via hydraulic fluid and it pushes the piston out gently. This means you're much less likely to strip the threads as what happens with the non-hydraulic splitters. I've used this lots of times now and it makes the job so easy you wouldn't believe it. Haven't damaged a single boot either.
Would be interesting to know how people find the gear pullers for jobs like this?
- troggy
- Thank you received: 360
:ohmy: £65 + :blink:weeleejimny wrote: Hydraulic Ball Joint splitter like the Sealey VS3811
Be careful not to catch the rubber boot. You can buy universal rubber boots on a card at some enlightened motorfactors.
Probably best to just buy a track rod end splitter, they are much cheaper than a new track rod end.
eg eBay item 321375724869 but you need the right size, or the scissor type.
Either one, tighten it on and before you bend anything a sharp tap from the hammer will split a reluctant joint.
mickt wrote: The ones you photoed are very easily broken, they are very brittle and do split the boots. If you loosen off the nut to the end of its thread and use a hammer or two and strike the arm the ball joint goes in they can just drop out, sometimes! I use this type ebay item number 110763406191 is an example. There is one for £11.29 posted. I have had mine years and it has never failed. The joint is a taper fit and some are tighter than others. Even using this type I have had to also use a hammer on the tool to shock the joint apart on some vehicles!
I go with this. Striking the ball joints arm is the one to try first. The forks make a real mess (and I like to refit as much as possible) and often can't be accessed in a confined space. The ebay one mentioned is the type I use or this version if space is at a premium, ebay #281552089318. And still a hammer may be needed just as stated.
Just one thing, if the nut is a tight fit on the thread through rust or whatever, I remove it completely first (and then maybe replace it to protect the threads)or it the nut will simply spin the ball instead of coming off and unfortunately this has been the way in nearly all my track rod end separations. If it does spin use a jack under the ball joint to push it back and then release the nut off.
- mc_nebula
