Brake Failure
14 Dec 2014 18:18 #132333
by facade
Replied by facade on topic Brake Failure
Could be swarf from making the new pipes, or, there is a tiny bit of flexible hose between the body and chassis above the front axle that could have gone bad.
Actually, if all the lines have been replaced, the rear brake cut off valve may be piped up wrongly. There are pipes from both front & rear going to it, although I can't see how they could stop the fronts working at all.
The rear line goes through the valve to the drums, so the rear brakes are cut off when the axle drops, except when there is no front line pressure. The front line ends at a bleed nipple on the valve.
- ZukracerV6
03 Jan 2015 20:01 #134022
by ZukracerV6
Replied by ZukracerV6 on topic Brake Failure
Thanks for all your help guys, turns out it was the master cylinder! On with the next problem (see new post) (-:
Time to create page: 0.082 seconds
