Brake Failure
  • ZukracerV6
11 Dec 2014 22:08 #132141 by ZukracerV6
Brake Failure was created by ZukracerV6
Hey Everyone,
Could do with some help on this one! I've just picked up my Jimny from its MOT this evening and as I came up to a road junction, I hit the brakes to slow down, the brake peddle went really hard and I lost alll braking! Luckily the junction was clear as I sailed straight though it. Pumping the brake did nothing. I rolled to a stop, tried the brakes again and they worked like normal.
The Jimny had just had all its brake lines replaced, so I drove it the mile or so back to the garage, trying the brakes as I went along and they worked fine. The garage then put it on the rolling road and also took it out for a drive and the brakes were perfect. I took it for another longer drive and found I could replicate the brake failure if I was in 4th gear, 30 mph, coasting to a stop (in gear) with my foot lightly pressed on the brake peddle for a few seconds before fully pushing the peddle to try and stop the Jimny. At that point the peddle would go hard, and I would lose all brakes! So I'm thinking brake servo and vacuum lines?
The vehicles is a 2000 Jimny manual, with a 1.6 engine, Rock lobster box and 4.5 lift. The vacuum hubs have been removed and converted to manual ones. Before the MOT and brake line change I never had a brake issue.
12 Dec 2014 00:20 #132159 by facade
Replied by facade on topic Brake Failure
Sounds like the servo.
Could be the pipe to the servo leaking, or the non-return valve in the servo (the white plug pushed through a grommet that connects to the vacuum pipe)
or the vacuum pipe collapsed inside blocking itself.
Might even be the servo itself, but check the rubber pipe & valve first.
  • helijohn
12 Dec 2014 19:48 #132217 by helijohn
Replied by helijohn on topic Brake Failure
ZukracerV6 wrote: The Jimny had just had all its brake lines replaced, Before the MOT and brake line change I never had a brake issue.
Was it a total loss of brakes (pedal drops to floor) or just a feeling of needing to use a lot of wellie to work them. Sometimes it is possible to drain the servo then the brakes feel really hard. In days before servos a lot of pressure was needed and today's brakes are really much easier. When you park up try pumping the brakes to expel the vacuum (if such a thing is in the laws of physics) and feel the brake action then.
  • ZukracerV6
14 Dec 2014 12:04 #132304 by ZukracerV6
Replied by ZukracerV6 on topic Brake Failure
No, the peddle went down a few inches and went completey solid with no effect on stoping the Jimny! When it happens pumping the brake no difference.
I also drive a 71 year old Jeep so, I'm very familiar with non servo assistant brakes! When this fault happens you can press the brake as hard as can, if fact you can stand on it and it makes no difference.
14 Dec 2014 13:41 #132314 by facade
Could be a lump of something in the brake pipe to the fronts that moves to block the pipe off when you give a sharp press on the pedal.
  • BigAndy
14 Dec 2014 15:08 #132322 by BigAndy
Replied by BigAndy on topic Brake Failure
First guess would be blockage. If it's a servo the brakes could stay on.
Time to create page: 0.984 seconds
