Reverse switch.
  • jonesyba420
11 years 11 months ago #130925 by jonesyba420
Replied by jonesyba420 on topic Re:Reverse switch.
Cheers jimbo.
All info helps.
  • mickt
11 years 11 months ago #130933 by mickt
Replied by mickt on topic Reverse switch.
I did mine not long ago. It looks daunting as from underneath you can barely see it. But it is reasonably easy especially if you have not go too big an arm. Trick is to get the new switch in your hand so that you can get the right size spanner ready and away you go. The switch should come with a new O ring seal but ensure it has one before putting the new one in. As mentioned earlier getting the plug disconnected without damaging the wires is the hardest bit as two hands are needed. But if my short fat 66 year old arms can do it then anybody's can! I did mine from underneath. Remember safety and use axle stands!
11 years 11 months ago #130945 by Busta
Replied by Busta on topic Reverse switch.
I laid across the engine and reached down to do mine- pretty straight forward. I bypassed the switch on the gearbox though, and added a switch on the dash so I can have the reversing lights on on demand. Quite useful if you're messing around in the woods in the dark, hooking up trailers and stuff.
  • jonesyba420
11 years 11 months ago #131041 by jonesyba420
Cheers for all the advice.
Ive been told i have no number plate lights either.........could this be related?
  • mickt
11 years 11 months ago #131043 by mickt
Have you checked the fuses. They should tell you if the circuits are linked power wise. The number plate light harness runs across the rear of the rear bumber so it would be worth checking for condition, broken connections etc.
11 years 11 months ago - 11 years 11 months ago #131102 by kirkynut
Replied by kirkynut on topic Reverse switch.
www.bigjimny.com/index.php/forum?view=to...imitstart=0&start=12
Have a look at this thread.
I think I found my old switch the other day - god knows why I kept it. I'll see if I can find it and measure what size spanner fits it. It is about 21/22mm from memory.
Edit: nope, can't find it. I don't know if I did see it after all. I'm pretty sure it's 22mm though.
Last edit: 11 years 11 months ago by kirkynut.
Time to create page: 0.105 seconds
