Reverse switch.
  • jonesyba420
11 years 11 months ago #130884 by jonesyba420
Reverse switch. was created by jonesyba420
Anyone done a guide or can point me in the right direction?
Cheers folks.
  • jonesyba420
11 years 11 months ago #130888 by jonesyba420
Replied by jonesyba420 on topic Re:Reverse switch.
I mean the reverse light switch.
I have no reverse lights and the bulbs are fine so guessing its the switch.
  • Yellostreak
11 years 11 months ago #130889 by Yellostreak
Replied by Yellostreak on topic Re:Reverse switch.
switch is on the gearbox.. on the top... the wiring I think comes forward and into the engine bay where there is a 2 way connector..
its a simple push to make switch so disconnect the plug that comes into the engine bay and short out the two connectors that are on the engine bay side of the connection with the car in reverse, engine off and ignition on the lights will come on... if not.. check for voltage across those two pins then separately to an earth/chassis point.. if there is nothing then there is a fuse/loom fault somewhere.
  • jonesyba420
11 years 11 months ago #130891 by jonesyba420
Cheers chaps, my GF has ordered me a switch (hopefully its the right one) so ill just change it. Is it easy and obvious to get to or is there some trick i need to know lol?
  • Yellostreak
11 years 11 months ago #130912 by Yellostreak
its probably a gearbox out job to get it out... :( I'd test it first like I said.. you can also put a continuity tester across the switch side of that connector..
11 years 11 months ago - 11 years 11 months ago #130917 by Jimbospanner
Replied by Jimbospanner on topic Re:Reverse switch.
100% not a gear box out job!
I've done mine twice.
Best access point is under the bonet (near side) top of gear box. Hardness bit was to disconnect the quick release conection. Make sure you do this first as not to twist the wires.
You can also get access under the car, but I found this a bit harder as you are blind when trying to get a spanner on it.
Hope that helps.
Last edit: 11 years 11 months ago by Jimbospanner.
Time to create page: 0.094 seconds
