Diff locker for front axel
- xtremedetailz
Busta wrote:
horam_jimny wrote: From reading quite a few posts over the years about a rear diff locker (Lockrite I think is the most common) that is permenantly installed as opposed to the ARB style air lockers. It seems that if your car is a daily driver too then they're not the most comfortable to live with.
Why don't they do a Lockrite style one for the front axel? Seeing as it isn't engaged when driving on road it wouldn't cause any issues for normal driving (assuming you had the vacuum system or manual hubs installed) yet when you're offroad and engaged 4wd it would be working as it should?
There must be issues with this theory as otherwise I'm sure it would be more popular but I can't seem to work out what they are.
No issues with your theory- it's a popular way to run a cheap locker on daily-drivers in America and Australia. It's just a shame there isn't the hardware available to do it on a Jimny!
Does rob storr not offer a front conversion kit for the lockrite?
Im sure i seen it on his website.
- jimnydms
- rexthecat
Diff locks in the front are great where you want 100% traction! stick it in low 1 and crawl up stuff at tick over while discos try and charge up up and just wheel spin near the top.
Diff locks are great but you'd only need to use them a tiny amount of the time.
- TomDK
rexthecat wrote: Trouble with putting a diff lock in the front axel you cant disengage in the front axel is once your in 4wd your diffs locked which means the wheels turn at the same speed, to go round a corner they need to turn at different speeds. Not all off roading is on a surface that let your wheels slip easily. Hard dry mud is like concrete, if the wheel cant spin its gonna stain the half shafts. It's not like you cant turn atall but the turning circle is much bigger. A lot of the time off roading you want to get round tight spots, a diff lock on all the time would make a pretty crap off roader I reckon.
Agreed
Which is why a lockright in the front diff is a bad idea if you ask me.
And also when locking the diff you put all the power and torque to one wheel making shafts and CVs more prone to breaking. So uprated shafts and CVS is a must. But still a bad idea. Only locker for the front diff is an air locker.
- Leathery1
If you need that kind of traction then spend the money and do ARBs front and rear.
My lockrite has to come out before it snows this winter as I can just imagine what would happen, but I LOVE the traction it provides when you get in a sticky situation off road. I cant justify the cost of ARBs on a daily drive (unless I have a lottery win some time soon!)
If a lockrite works as it should (e.g. locks when one wheel loses traction, unlocks when both have traction) then I can't see the problem? We're not talking about welding up the diff- A lockrite is not always locked, so wouldn't be the same as trying to turn with a locked ARB.
