Valve stem oil seals
07 Aug 2020 15:11 #226239 by Roger Fairclough
Yes it does work but you need to be at TDC for safety and you can finish up a dead end street because you now have to compress the valve spring to remove the collet and spring cap to get at the oil seal. Normal valve compressors push against the valve head to do this.
Roger
  • Valleymills
07 Aug 2020 15:19 #226241 by Valleymills
Replied by Valleymills on topic Valve stem oil seals
Thanks. I was thinking of using the rope trick but maybe it would be best to rake the head off. Since the engine is still going well except for the smoke on start up I was considering leaving well alone.
07 Aug 2020 15:24 - 07 Aug 2020 15:25 #226243 by Scimike
Replied by Scimike on topic Valve stem oil seals
Sealey sell the bits to do the compressor air hold up and spring compressor tool that allows you to keep the head on.
Never used them, but had a search see what I could find.
workshopping.co.uk/automotive-service-to...9TJN4qBoCcVsQAvD_BwE
Last edit: 07 Aug 2020 15:25 by Scimike.
07 Aug 2020 18:08 #226252 by Roger Fairclough
It's a general purpose tool that may or may not work and either way it may or may not cause damage to adjacent parts. I have worked on engines all my practical life and I wouldn't touch one with the proverbial barge pole.
By the way, what colour is the smoke.
Roger
  • Valleymills
07 Aug 2020 19:33 #226261 by Valleymills
Smoke is blue on start up. It clears after a few seconds.
07 Aug 2020 20:20 #226269 by Lambert
Replied by Lambert on topic Valve stem oil seals
Is there any more smoking on the overrun?
Time to create page: 0.164 seconds
